Off Topic Question, Cut out on VW Jetta |
partwerks |
Aug 25 2014, 10:01 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Within the first 4 minutes of a cold engine, my 96 VW Jetta, has this thing where it will intermittently cut out. If you happen to be stopped, one of two things, if you let it run it's course, then the idle will fluctuate up and down from about 700 to 900 for about 5 seconds, or there abouts, and then the idle goes high to about 1200, for about 5 seconds, and comes down to normal idle.
On the other hand, if you slam the pedal down, and let back up quck, it tends to clear it out, and everything is normal. Otherwise, it runs just fine once it has it's fit. I've cleaned all the grounds that I know of, and replaced the coolant temp sensor, and throttle body, but not sure what is causing it?? I'm hoping someone might have an idea on what is causing it. It would almost make me think that it is something that when it first warms up? Any, thoughts, ideas, or suggestions? |
partwerks |
Aug 27 2014, 09:35 PM
Well I hope the mechanic finds out what it's problem is. It did not want to stay running this morning, but for about 5 seconds, and shut off. No engine check light. I was able to limp it down to a mechanc about a mile across town, with restarting it about 25 times. When konking out, I would let it roll a ways, and kept millking it. Sometimes to floor board it, it would tend to catch, but definitely is NOT running right.
I don't know if there are codes that don't set off the engine check light, that may show up on a scanner? |
Lo-Fi Version | Time is now: 17th May 2024 - 03:48 PM |
