Mechanical Oil Pressure Gauge, - does it need to be bled? |
Kansas 914 |
Aug 26 2014, 08:52 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I have a VDO oil pressure gauge in the center console gauge cluster. It is a mechanical gauge - oil line from the sending unit location on the top of the engine to the back of the gauge. I noticed this weekend the line near the gauge is full of air and only a little bit of oil in the line. Should I "bleed" the line somehow. If so how is that done?
Can I just open the line at the gauge and keep it higher than the sending unit area so the air will rise? Thanks in advance! |
76-914 |
Aug 26 2014, 09:06 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Air is OK. Doesn't change the indicated pressure reading.
00r101 |
Aug 26 2014, 09:21 AM
Newbie Group: Members Posts: 17 Joined: 24-May 12 From: United States Member No.: 14,476 Region Association: MidAtlantic Region |
Air is OK. Doesn't change the indicated pressure reading. Ahhh, My high school physics says that a gas is compressible but a liquid is not as much. So air in the line will be compressed a bit as oil pressure changes. But whether it will make a huge diff in the oil pressure reading I do not know. Air in the line will start off at 14.7 psi so how much it will compress at say 60 psi i might be minimal |
mikesmith |
Aug 28 2014, 08:56 PM
Member Group: Members Posts: 202 Joined: 5-September 13 From: SF Member No.: 16,354 Region Association: Northern California |
Air is OK. Doesn't change the indicated pressure reading. Ahhh, My high school physics says that a gas is compressible but a liquid is not as much. So air in the line will be compressed a bit as oil pressure changes. But whether it will make a huge diff in the oil pressure reading I do not know. Air in the line will start off at 14.7 psi so how much it will compress at say 60 psi i might be minimal The pressure from the oil side in the line will be X psi. This will compress the air until the pressure from the air side is also X psi. With air in the line, the gauge will move a little slower (since oil will have to flow up/down the line as the pressure changes), but once it's stable, the air pressure will match (precisely) the oil pressure. This is also high-school physics. Remember the water column experiment? |
mgp4591 |
Aug 29 2014, 12:13 AM
914 Guru Group: Members Posts: 5,374 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Lo-Fi Version | Time is now: 17th May 2024 - 04:14 PM |
