Radiator hoses |
Radiator hoses |
partwerks |
Aug 27 2014, 06:31 AM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
On the undercarriage of the car mainly, any ideas for subsititutes that can be used instead of hoses? I've seen where some have used rectangular tubing that went into the depression.
mgp4591 |
Aug 27 2014, 12:18 PM
914 Guru Group: Members Posts: 5,374 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
SOT, how would radiator hoses run thru the longs work? Too many curves and restrictions or totally doable?
Chris H. |
Aug 27 2014, 02:09 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
SOT, how would radiator hoses run thru the longs work? Too many curves and restrictions or totally doable? Doable for sure. Kent (76-914)'s are run through the longs. Many others as well. The issue (sometimes) is getting the air out of the system initially. Once you do that it's fine. The longs MIGHT also get warm (or so I heard). |
mgp4591 |
Aug 27 2014, 02:20 PM
SOT, how would radiator hoses run thru the longs work? Too many curves and restrictions or totally doable? Doable for sure. Kent (76-914)'s are run through the longs. Many others as well. The issue (sometimes) is getting the air out of the system initially. Once you do that it's fine. The longs MIGHT also get warm (or so I heard). Only one probably, from the engine to the radiator. Warm longs in Utah probably not a bad thing either... or in Chicago (IMG:style_emoticons/default/idea.gif) Now running them thru the center tunnel like I've heard, not too crazy about that one. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:17 PM |
