car is bucking under acceleration...any ideas? |
era vulgaris |
Aug 27 2014, 02:04 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
My car has developed an extremely annoying bucking under acceleration. It started about a week ago, and at first it would only happen while accelerating out of a fast turn. But now it does it all the time while accelerating. It's like the car is oscillating between half power and full power, making it lurch-slow-lurch-slow-lurch-slow. It's like you're riding a bucking bronco or something. The only cure seems to be to get off the throttle completely, upshift, then slowly accelerate.
Anyone have any idea where I should start looking first? |
era vulgaris |
Aug 27 2014, 04:32 PM
Motor mounts and trans mounts are still good.
TPS has been on my to do list. I should check it anyway. The stumble isn't while cruising though, which I understand is what happens with the TPS. My problem's only with acceleration. Yup, still D jet - it's in the sig! (IMG:style_emoticons/default/wink.gif) It's anyone's guess if the tank has been cleaned or the screen replaced. I've only owned the car since last november, and I wouldn't trust a word the PO says about it. That seems logical though, considering the issue started with hard cornering. Maybe some sludge got knocked loose. |
brp986s |
Aug 27 2014, 07:31 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
Motor mounts and trans mounts are still good. TPS has been on my to do list. I should check it anyway. The stumble isn't while cruising though, which I understand is what happens with the TPS. My problem's only with acceleration. The TPS provides accel enrichment. You can spot check by turning ign on w/o starting engine, then go to engine and operate throttle valve. You should hear clicks from the injectors firing. |
Lo-Fi Version | Time is now: 26th May 2024 - 09:18 PM |
