car is bucking under acceleration...any ideas? |
era vulgaris |
Aug 27 2014, 02:04 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
My car has developed an extremely annoying bucking under acceleration. It started about a week ago, and at first it would only happen while accelerating out of a fast turn. But now it does it all the time while accelerating. It's like the car is oscillating between half power and full power, making it lurch-slow-lurch-slow-lurch-slow. It's like you're riding a bucking bronco or something. The only cure seems to be to get off the throttle completely, upshift, then slowly accelerate.
Anyone have any idea where I should start looking first? |
dknechtly |
Aug 28 2014, 07:55 AM
Yellow 914 Group: Members Posts: 68 Joined: 11-April 03 From: Wylie, TX Member No.: 560 Region Association: None |
There's a lot of good advice here. Make sure your vacuum advance is working good. Check that your mechanical advance weights are moving freely and the springs are all good. Timing correctly set? If you clean the trigger points, make sure to only use something like a note card. DO NOT use emory cloth! These things need to shine. You want the resistance as low as possible.
Lo-Fi Version | Time is now: 27th May 2024 - 01:21 AM |
