car is bucking under acceleration...any ideas? |
era vulgaris |
Aug 27 2014, 02:04 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
My car has developed an extremely annoying bucking under acceleration. It started about a week ago, and at first it would only happen while accelerating out of a fast turn. But now it does it all the time while accelerating. It's like the car is oscillating between half power and full power, making it lurch-slow-lurch-slow-lurch-slow. It's like you're riding a bucking bronco or something. The only cure seems to be to get off the throttle completely, upshift, then slowly accelerate.
Anyone have any idea where I should start looking first? |
Rand |
Sep 2 2014, 06:20 PM
QUOTE Make sure you have at least 30 PSI available at fuel rails. Factory setting was 28 PSI but that was when gas was "real" gas. Disregard that since you have a carb now. You don't have fuel rails anymore. Your carb only wants about 5 PSI. Check your new filter. If there was a bunch of crap in the bottom of the tank it could have clogged the new filter quickly. |
era vulgaris |
Sep 2 2014, 07:12 PM
QUOTE Make sure you have at least 30 PSI available at fuel rails. Factory setting was 28 PSI but that was when gas was "real" gas. Disregard that since you have a carb now. You don't have fuel rails anymore. Your carb only wants about 5 PSI. Check your new filter. If there was a bunch of crap in the bottom of the tank it could have clogged the new filter quickly. What? Actually I don't have a carb and I do have fuel rails. Note the car listed in my signature (IMG:style_emoticons/default/poke.gif) The car has been performing better since the new filter. Still just trying to work out the last issue under hard cornering. |
Lo-Fi Version | Time is now: 18th May 2024 - 11:46 PM |
