car is bucking under acceleration...any ideas? |
era vulgaris |
Aug 27 2014, 02:04 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
My car has developed an extremely annoying bucking under acceleration. It started about a week ago, and at first it would only happen while accelerating out of a fast turn. But now it does it all the time while accelerating. It's like the car is oscillating between half power and full power, making it lurch-slow-lurch-slow-lurch-slow. It's like you're riding a bucking bronco or something. The only cure seems to be to get off the throttle completely, upshift, then slowly accelerate.
Anyone have any idea where I should start looking first? |
914_teener |
Sep 2 2014, 10:22 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I would suggest a few things. A new fuel tank sock on the return line at the fuel tank... Check all your fuel lines. Check all your wiring, make sure all the fuel injection wiring is properly connected and not loose...it happens. Do new points, new plugs, and new wires, rotor and distributor cap. Remove the advance plates and clean then inside the distributor...40 year old grease is like glue now... Remove the if trigger points and blow out all the crap from the bottom of the distributor. Full tune up Set valves Set dwell Set timing Check fuel pressure. Now you would have eliminated a large number of variables...it's just a good place to start. Couple of extra things I thought of: Check your injectors for flow since your filter was plugged. Check your MPS....hopefully it is bolted down in the bracket with spark plug wires not near it and not just hanging somewhere. That might explain the cornering issue. My .02. |
era vulgaris |
Sep 3 2014, 09:08 AM
Couple of extra things I thought of: Check your injectors for flow since your filter was plugged. Check your MPS....hopefully it is bolted down in the bracket with spark plug wires not near it and not just hanging somewhere. That might explain the cornering issue. My .02. I'll check my injectors again. I did this crap in the wrong order! I went injectors->filter->tank. Doh! At least I know better now, ha! MPS is bolted down snug. I had to pull it out of the way when I replaced my injectors, and I made sure it was nice and secure when I replaced it. |
Lo-Fi Version | Time is now: 18th May 2024 - 09:45 PM |
