car is bucking under acceleration...any ideas? |
era vulgaris |
Aug 27 2014, 02:04 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
My car has developed an extremely annoying bucking under acceleration. It started about a week ago, and at first it would only happen while accelerating out of a fast turn. But now it does it all the time while accelerating. It's like the car is oscillating between half power and full power, making it lurch-slow-lurch-slow-lurch-slow. It's like you're riding a bucking bronco or something. The only cure seems to be to get off the throttle completely, upshift, then slowly accelerate.
Anyone have any idea where I should start looking first? |
jacksun |
Sep 3 2014, 07:52 PM
Member Group: Members Posts: 236 Joined: 8-August 13 From: mi Member No.: 16,224 Region Association: Upper MidWest |
hi, maybe the below will help?
"Throttle Switch by Kjell Nelin The throttle switch can be found mounted underneath the throttle body. To test, turn on the ignition and open the throttle with your hand. You should be able to hear the injectors firing, a sort of "brrrrrrp" noise. If working correctly, the injectors will fire 20 times for the full range of movement. One very mysterious intermittent fault caused by the throttle switch is an occasional "bucking" while driving at constant speed. This is caused by the switch cutting of the fuel and then turning it back on. Test by disconnecting the switch (it is amazing how well the car will run without it, actually), you will notice that acceleration will be a little sluggish as the "accelerator pump" action will be missing. " |
Lo-Fi Version | Time is now: 19th May 2024 - 12:11 AM |
