WTB: renegade CV JOINTS AND AXLES |
ringerdc |
Aug 28 2014, 03:22 PM
Newbie Group: Members Posts: 11 Joined: 28-January 13 From: Calistoga, Northern California Member No.: 15,443 Region Association: Northern California |
Looking to buy a set of renegade rear axles with CV joints for a V8 application. Having a bit of sticker shock at $700 for a new set. Anyone have a decent pair at a decent price?
grimmel |
Aug 28 2014, 03:46 PM
grimmel Group: Members Posts: 5 Joined: 29-September 11 From: Sacramento, CA Member No.: 13,623 Region Association: Central California |
ScatVW makes heavy duty axles, $100 per side.
Shoot them an email and see if they would work. They are very good about getting back to you. grimmel http://scatvw.com/master/transmission/ RACING I.R.S. AXLE ASSEMBLY-1SIDE Made from Harden Steel Part# Description Price Buy Online 70215 Racing I.R.S. Axle Assembly $99.00 |
grimmel |
Aug 28 2014, 05:57 PM
If you use a subie trans check out (the best way to go for availability & cheap spares)
http://www.coldwater914.com/hybrid-axle-375/ Hybrid Axle $375 These custom, 4340 alloy, Sway-A-Way axles bridge the gap between the Subaru transmission and the 914 hubs. With Subaru splines on inside the axle will fit 02-04 OEM wrx 5mt DOJs (which will slide on to most any subaru transmission). While on the outside Sway-A-Way’s signature free floating splines accept both the 914 and 944 CV joint. To order please email me at ian@coldwater914.com |
ringerdc |
Aug 28 2014, 09:43 PM
Thanks for the heads up. I will see if the scat axles will work for my application.
Lo-Fi Version | Time is now: 25th April 2024 - 05:54 AM |
