Trailing Arm Bushings, What material to select? |
malcolm2 |
Aug 28 2014, 03:32 PM
I need to replace the rear wheel bearings, so "while I am in there" I will also tackle the bushings.
Rubber looks to be the OEM choice but is hard to find with the exception of the elephant racing kit that includes the shafts and install tools. $300+ I used the Elephant bushings on the front. I found poly-graphite to be the least expensive < $20 for a set of 4 bushings only With Delrin as the middle of the road choice. @ $50 for a set of 4 bushings only So what is the +/- of each material? Can you throw a few vendors out there? My car is a daily driver? Clark |
Markl |
Aug 28 2014, 04:15 PM
Member Group: Members Posts: 75 Joined: 14-September 09 From: Colorado Member No.: 10,802 Region Association: Rocky Mountains |
I just put poly bushings on - PITA! They aren't made for the 914, they are just kind of the right size. I spent way too much time honing and fitting.
Worst of all, they are noisy, even with the right grease. I mean, the car hasn't gone 10 feet under it's own power and the squeaking is amazing. So I'm saving for Elepahant or Rebel Racing bushings - I won't drive the car with that kind of racket going on. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:30 PM |
