Trailing Arm Bushings, What material to select? |
malcolm2 |
Aug 28 2014, 03:32 PM
I need to replace the rear wheel bearings, so "while I am in there" I will also tackle the bushings.
Rubber looks to be the OEM choice but is hard to find with the exception of the elephant racing kit that includes the shafts and install tools. $300+ I used the Elephant bushings on the front. I found poly-graphite to be the least expensive < $20 for a set of 4 bushings only With Delrin as the middle of the road choice. @ $50 for a set of 4 bushings only So what is the +/- of each material? Can you throw a few vendors out there? My car is a daily driver? Clark |
lonewolfe |
Aug 28 2014, 08:49 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Here's the link to the Rebelracingproducts.com page that shows their rear bushing set for the 914.
http://www.rebelracingproducts.com/SuspSteerpage2.html |
malcolm2 |
Aug 28 2014, 09:23 PM
Here's the link to the Rebelracingproducts.com page that shows their rear bushing set for the 914. http://www.rebelracingproducts.com/SuspSteerpage2.html I guess i'll call. Need to ask if $199 does a car or a side. They spell it out on the part above for another car, but it is not clear for the 914. |
malcolm2 |
Aug 29 2014, 10:17 AM
Here's the link to the Rebelracingproducts.com page that shows their rear bushing set for the 914. http://www.rebelracingproducts.com/SuspSteerpage2.html I guess i'll call. Need to ask if $199 does a car or a side. They spell it out on the part above for another car, but it is not clear for the 914. No answer yet, you cali boys don't start working too early, do ya? I'll leave a message on the 3rd try. My method on this project is to rebuild some spare trailing arms purchased from a 74 in the JY. $15 each. Then take an afternoon and install them on my '75. That way I can drive with the loud bearing a bit longer. Bearings and bushings are now out of the spare arms. One arm had nice looking bushings and one of our experts (on another board) suggested that I not mess with the bushings if they "looked" OK. "you can't find the rubber ones, and it is one tough job" were a few other reasons. The picture below is the pivot shaft out of the arm with "good looking" bushings. And seems to be a good reason to replace 39 year old good looking parts. Water got under the bushing and has rusted the pivot shaft. Looks like money well spent will be to change the bushings and the arms, ya think? Turns out both of the donor arms have this problem, I bet my '75 does too. IIRC the bushings looked good on it. Clark |
Lo-Fi Version | Time is now: 17th May 2024 - 03:20 PM |
