Trailing Arm Bushings, What material to select? |
malcolm2 |
Aug 28 2014, 03:32 PM
I need to replace the rear wheel bearings, so "while I am in there" I will also tackle the bushings.
Rubber looks to be the OEM choice but is hard to find with the exception of the elephant racing kit that includes the shafts and install tools. $300+ I used the Elephant bushings on the front. I found poly-graphite to be the least expensive < $20 for a set of 4 bushings only With Delrin as the middle of the road choice. @ $50 for a set of 4 bushings only So what is the +/- of each material? Can you throw a few vendors out there? My car is a daily driver? Clark |
MikeM |
Aug 30 2014, 05:33 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
With respect to the rear trailing arm bushings, if you had a choice between the Rebel Racing bushings, or the Elephant rubber bushings, which would you choose?
Street car only. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:58 PM |
