Trailing Arm Bushings, What material to select? |
malcolm2 |
Aug 28 2014, 03:32 PM
I need to replace the rear wheel bearings, so "while I am in there" I will also tackle the bushings.
Rubber looks to be the OEM choice but is hard to find with the exception of the elephant racing kit that includes the shafts and install tools. $300+ I used the Elephant bushings on the front. I found poly-graphite to be the least expensive < $20 for a set of 4 bushings only With Delrin as the middle of the road choice. @ $50 for a set of 4 bushings only So what is the +/- of each material? Can you throw a few vendors out there? My car is a daily driver? Clark |
lonewolfe |
Sep 16 2014, 05:45 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Yes, the threaded shafts that go through the RR metal tubes and within the bushings are missing. I didn't have those shafts handy for the photographs. You can see how these parts are all oriented on the rebelracingproducts.com website in the illustration.
malcolm2 |
Sep 16 2014, 07:00 PM
Yes, the threaded shafts that go through the RR metal tubes and within the bushings are missing. I didn't have those shafts handy for the photographs. You can see how these parts are all oriented on the rebelracingproducts.com website in the illustration. Well my problem is that I guess I am too literal. I see a picture, or a drawing and I make a purchase and I expect to get what I see. I need the damn pivot arms. In posts above you can see that mine are rusted. Their website showed the product with the pivot arm assembled and never stated that IT was not included. Am I crazy to expect the part to show up as pictured? Or should I just use the rusted pivot arm? Clark |
ChrisFoley |
Sep 16 2014, 07:05 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Or should I just use the rusted pivot arm? Clark I've been selling new pivot shafts for years. I can't tell you if they'll fit the Rebel bushings (they fit my bushings), but my shafts are made to exacting standards, and are virtually the same diameter as the stock original shafts. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:13 PM |
