Trailing Arm Bushings, What material to select? |
malcolm2 |
Aug 28 2014, 03:32 PM
I need to replace the rear wheel bearings, so "while I am in there" I will also tackle the bushings.
Rubber looks to be the OEM choice but is hard to find with the exception of the elephant racing kit that includes the shafts and install tools. $300+ I used the Elephant bushings on the front. I found poly-graphite to be the least expensive < $20 for a set of 4 bushings only With Delrin as the middle of the road choice. @ $50 for a set of 4 bushings only So what is the +/- of each material? Can you throw a few vendors out there? My car is a daily driver? Clark |
ChrisFoley |
Sep 16 2014, 09:15 PM
I am Tangerine Racing Group: Members Posts: 7,927 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Using factory shafts with precision bearing or bushing installations ensures that a loose fit will be required or the system will bind.
The shafts were never intended to serve as a bearing surface, and glueing bearing sleeves on them does not improve the poor colinearity from one end to the other. |
Lo-Fi Version | Time is now: 20th May 2024 - 11:39 PM |
