Trailing Arm Bushings, What material to select? |
malcolm2 |
Aug 28 2014, 03:32 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I need to replace the rear wheel bearings, so "while I am in there" I will also tackle the bushings.
Rubber looks to be the OEM choice but is hard to find with the exception of the elephant racing kit that includes the shafts and install tools. $300+ I used the Elephant bushings on the front. I found poly-graphite to be the least expensive < $20 for a set of 4 bushings only With Delrin as the middle of the road choice. @ $50 for a set of 4 bushings only So what is the +/- of each material? Can you throw a few vendors out there? My car is a daily driver? Clark |
ChrisFoley |
Sep 16 2014, 09:15 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Using factory shafts with precision bearing or bushing installations ensures that a loose fit will be required or the system will bind.
The shafts were never intended to serve as a bearing surface, and glueing bearing sleeves on them does not improve the poor colinearity from one end to the other. |
914_teener |
Sep 16 2014, 09:34 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Using factory shafts with precision bearing or bushing installations ensures that a loose fit will be required or the system will bind. The shafts were never intended to serve as a bearing surface, and glueing bearing sleeves on them does not improve the poor colinearity from one end to the other. (IMG:style_emoticons/default/agree.gif) This is true. Originally it was a thermo bonded system that was manufactured in a fixture to maintain the geometry. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:34 PM |
