Trailing Arm Bushings, What material to select? |
malcolm2 |
Aug 28 2014, 03:32 PM
I need to replace the rear wheel bearings, so "while I am in there" I will also tackle the bushings.
Rubber looks to be the OEM choice but is hard to find with the exception of the elephant racing kit that includes the shafts and install tools. $300+ I used the Elephant bushings on the front. I found poly-graphite to be the least expensive < $20 for a set of 4 bushings only With Delrin as the middle of the road choice. @ $50 for a set of 4 bushings only So what is the +/- of each material? Can you throw a few vendors out there? My car is a daily driver? Clark |
crash914 |
Sep 18 2014, 11:17 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
JB weld is some wonderful stuff....I rebuilt some damage on a front spindle with it on an old pick up truck I have. finished to size and the front wheel bearing slid right on....5 years later, no issues....It isn't a cure all for everything though..for that you need WD-40 and duct tape. Stay away from silicone sealer! or you will die
Lo-Fi Version | Time is now: 17th May 2024 - 02:42 PM |
