73 SoCal Rebuild |
73 SoCal Rebuild |
Nate |
Aug 28 2014, 04:24 PM
Newbie Group: Members Posts: 47 Joined: 21-August 14 From: Southern California Member No.: 17,807 Region Association: Southern California |
Hey guys,
Recently joined this forum as I started working on a 73 914 2.0. The last time the car ran it was making a bad noise. It hasn't run in about 15 years. I pulled the motor and started taking everything apart. I have to say that the flat head screws that hold most of the engine cooling sheet metal on are a damn pain in the ass. The flywheel turned freely and nothing seemed seized. The motor is pretty high mileage. Somewhere around 200k. The odometer stopped working around 140k miles. So enough talking, here are some pictures of where I am with the project right now. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1292.photobucket.com-17807-1409264677.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1292.photobucket.com-17807-1409264677.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1292.photobucket.com-17807-1409264677.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1292.photobucket.com-17807-1409264677.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1292.photobucket.com-17807-1409264677.5.jpg) And here is the car it came out of. It's always been a California car so the rust is minimal. Only a couple places of cosmetic rust. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1292.photobucket.com-17807-1409264678.6.jpg) I'm in the process of pulling the cylinders and pistons and then I'm gonna decide whether I want to split the case or not. I don't really want to make this car into a race car or anything. Just get it running and driving well. That being said, I don't want to dump $1000 into new pistons and cylinders. Anyone have any good options? Cylinder honing? |
Dave_Darling |
Oct 17 2014, 09:20 PM
The "fuse holder" is just a connector. The male part is usually held inside the plastic box, and the female part of the connector gets pushed in the other end.
The wire in the first pic is quite likely for the head temp sensor, the one that lives near the #3 spark plug. The green/red wire goes to the oil pressure switch near the distributor. That green wire off the distributor.... Could be the wire from the points/condenser to the (-) side of the coil? The ring terminal with lots of wires is indeed the common ground point for most of the fuel injection. The ring goes over the case bolt on top of the motor closest to the transmission end. --DD |
Lo-Fi Version | Time is now: 17th May 2024 - 02:49 PM |
