73 SoCal Rebuild |
73 SoCal Rebuild |
Nate |
Aug 28 2014, 04:24 PM
Newbie Group: Members Posts: 47 Joined: 21-August 14 From: Southern California Member No.: 17,807 Region Association: Southern California |
Hey guys,
Recently joined this forum as I started working on a 73 914 2.0. The last time the car ran it was making a bad noise. It hasn't run in about 15 years. I pulled the motor and started taking everything apart. I have to say that the flat head screws that hold most of the engine cooling sheet metal on are a damn pain in the ass. The flywheel turned freely and nothing seemed seized. The motor is pretty high mileage. Somewhere around 200k. The odometer stopped working around 140k miles. So enough talking, here are some pictures of where I am with the project right now. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1292.photobucket.com-17807-1409264677.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1292.photobucket.com-17807-1409264677.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1292.photobucket.com-17807-1409264677.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1292.photobucket.com-17807-1409264677.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1292.photobucket.com-17807-1409264677.5.jpg) And here is the car it came out of. It's always been a California car so the rust is minimal. Only a couple places of cosmetic rust. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1292.photobucket.com-17807-1409264678.6.jpg) I'm in the process of pulling the cylinders and pistons and then I'm gonna decide whether I want to split the case or not. I don't really want to make this car into a race car or anything. Just get it running and driving well. That being said, I don't want to dump $1000 into new pistons and cylinders. Anyone have any good options? Cylinder honing? |
914_teener |
Oct 19 2014, 09:48 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Just my two bits......
You may want to "ring" out that harness just to make sure the wiring is sound while it's out. Visually inspect the ground point ends and the areas around that looks hardened...so to make sure the wires aren't making intermittent contact. Sounds like you know what you are doing and realize how important electrical contacts are to D-jet running well. Make sure the vaccum hoses are refreshed and especially the fuel lines as they will be under more that 30psi. I'm using the new CARB rated hoses now for the fuel line....for the last 4 years with no cracking. Good luck.... (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:12 PM |
