Spark Plugs ~ general discussion |
dlestep |
Aug 29 2014, 10:55 AM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
Back in the day, not so long ago, there were concerns of heat range, indexing and such. One had to consider hot or cold plugs in air-cooled engines.
When twin plugging, one would reduce advance, which would reduce temperature and increase flame propagation. But now, there are so many ways to fire the plugs, and I have not seen anything written about the effects of using Nology wires, Hotwires, etc. expressing godzilla arc ? ~ Anyone have REAL input on this ? ~ What plugs are you running ? |
McMark |
Aug 29 2014, 01:48 PM
In my turbo 1.7 I upgraded from standard bosch plugs to some fancy $14 (EACH!) NGK plugs. Didn't notice a difference even after trying to tweak the tune files. Of course without a bunch of gauges, etc it can be hard to tell.
johnhora |
Aug 29 2014, 02:09 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Dave...first question is what engine is this application. Stock, Race, etc.
monkeyboy |
Aug 29 2014, 02:38 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
One thing I was told was that the stock ignition system doesn't make enough spark energy to make any of the fancy plugs worth it.
None of those fancy ignition parts were designed to work with points, condensors, and old coils. |
dlestep |
Sep 2 2014, 07:43 AM
In my turbo 1.7 I upgraded from standard bosch plugs to some fancy $14 (EACH!) NGK plugs. Didn't notice a difference even after trying to tweak the tune files. Of course without a bunch of gauges, etc it can be hard to tell. I am running an older (80's) twin point system. Never had a problem with them. I am considering Nology wires, but there is a nagging thought in the back of my mind, about heat range. I was thinking it would be a half-step toward a system I cannot afford right now. Anyone have any experience with Nology wires and coil ? |
Lo-Fi Version | Time is now: 25th April 2024 - 05:53 PM |
