Oil leak woes |
Oil leak woes |
Mikesavina |
Aug 30 2014, 11:50 PM
Newbie Group: Members Posts: 26 Joined: 15-September 12 From: Clarksburg WV Member No.: 14,936 Region Association: MidAtlantic Region |
Need some help tracking down my oil leak. I have oil all over the passenger side tin on the top, doesn't appear to be coming from breathers or oil fill tank, it's a complete mess with oil even on the firewall. I have ran it after cleaning and can't track down any leak, however after driving a short distance the tin is covered with oil even tracing the rear glass. So where in the heck could it be coming from? Oil cooler doesn't seem to be wet. Any help would be great
TheCabinetmaker |
Aug 31 2014, 01:20 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
A picture is worth a thousand words. Only need three in this case. Valve cover gasket.
The top of the gasket sags down and oil blows out the top of the cover onto the head and then behind the tin under the intake and onto the tin. Doesn't sound likely but ive seen it before. |
Mikesavina |
Aug 31 2014, 01:43 PM
A picture is worth a thousand words. Only need three in this case. Valve cover gasket. The top of the gasket sags down and oil blows out the top of the cover onto the head and then behind the tin under the intake and onto the tin. Doesn't sound likely but ive seen it before. I will pull the cover next then...it did seen odd that there was a significant amount of oil under the intake...had me wondering how it wa getting there. Thanks for the tip and I'll update as soon as I pull it tonight |
Lo-Fi Version | Time is now: 17th May 2024 - 02:50 AM |
