> fan assembly lower flaps, each side
jacksun
post Aug 31 2014, 06:46 AM
hi,
how important is it to keep the little flaps on each side of the
fan assembly housing? the flaps on the lower sides.
tks
randal
dlee6204
post Aug 31 2014, 07:38 AM
Howdy
Very important if you want some heat at idle. When your heater fan is blowing the flaps keep the air from being blown back to the engine. This is usually only at idle because the engine fan isn't blowing very much. Anything over idle and your engine fan is blowing more air and opening the flaps.
jacksun
post Aug 31 2014, 11:49 AM
would it be a good idea that the air from the heat exchangers is cycling back through
at idle to assist the warm up of the engine, by removing the flaps?
tks for your reply
randal
barefoot
post Sep 2 2014, 09:16 AM
QUOTE(jacksun @ Aug 31 2014, 01:49 PM) *
tks for your reply
randal
If the little flaps are removed, air from the heater fan will only blow back into the engine front fan and not back around the cylinders, so no benifit.
- Lo-Fi Version Time is now: 16th April 2024 - 11:30 AM
