What'd I do now? New clutch, no fuel pump running |
914bub |
Aug 31 2014, 12:13 PM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
Hey guys I need some help.
I got my 914 9 months ago. I traded it straight across for a car that a friend of mine wanted. The deal was we would both get each car running before the trade. The 914 needed a fuel pump and some tuning. It arrived running but needed a clutch and a master cylinder. I got the clutch done and now the car won't start. I've got power to two of the pins at the fuel pump relay but no power down to the pump. I "think" the relay os clicking but need to get an extra pair of hands over here to crank is as I can't find my remote starter. If I understand correctly the ECU grounds the pump to make it run? If that's the case should I always have power at the pump with the key on? The car runs on starting fluid so the ignition is working fine. Here's the rest of the story,(and yeah I feel stupid about this part). In my haste to button everything up I accidently plugged the 12 pin plug onto the relay board incorrectly. I plugged it in 1 pin off. Imagine if the #1 and 2 pins were plugged into 3 & 4 instead. I corrected that but just hope I didn't smoke something in the mean time. My dad also hooked the positive wire up to the negative side of the coil. ....That was good for a new set of points. Any input would be greatly appreciated. I have the diagram of the relay board that was posted in another thread. |
Bartlett 914 |
Aug 31 2014, 01:34 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
The fuel pump will only run for a few seconds after turning the key. Once the car starts, the pump will run continuously
914bub |
Aug 31 2014, 01:39 PM
The fuel pump will only run for a few seconds after turning the key. Once the car starts, the pump will run continuously Thanks. Is the ECU in fact grounding the pump as opposed to it energizing the fuel pump relay? I've also been told that every car, (no matter the make), that has D jet injection uses the same ecu? Do you know if that's true? I have an ECU out of a D jet injected 72 Volvo. I haven't checked any part numbers yet. Thanks for the input. |
Lo-Fi Version | Time is now: 15th May 2024 - 11:36 AM |
