What'd I do now? New clutch, no fuel pump running |
914bub |
Aug 31 2014, 12:13 PM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
Hey guys I need some help.
I got my 914 9 months ago. I traded it straight across for a car that a friend of mine wanted. The deal was we would both get each car running before the trade. The 914 needed a fuel pump and some tuning. It arrived running but needed a clutch and a master cylinder. I got the clutch done and now the car won't start. I've got power to two of the pins at the fuel pump relay but no power down to the pump. I "think" the relay os clicking but need to get an extra pair of hands over here to crank is as I can't find my remote starter. If I understand correctly the ECU grounds the pump to make it run? If that's the case should I always have power at the pump with the key on? The car runs on starting fluid so the ignition is working fine. Here's the rest of the story,(and yeah I feel stupid about this part). In my haste to button everything up I accidently plugged the 12 pin plug onto the relay board incorrectly. I plugged it in 1 pin off. Imagine if the #1 and 2 pins were plugged into 3 & 4 instead. I corrected that but just hope I didn't smoke something in the mean time. My dad also hooked the positive wire up to the negative side of the coil. ....That was good for a new set of points. Any input would be greatly appreciated. I have the diagram of the relay board that was posted in another thread. |
Tom |
Sep 1 2014, 08:26 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Hooking the 12 pin up one set of contacts off will put 12 Volts switched to the tach wire and coil negative. Whenever the key is turned to on, if the points are closed, well, smoke will escape. It may not have been your father's error after all! Should be tach wire (black/purple) and dizzy (green)to 1, positive (black) to 15. Melting a wire in a harness like this will damage other wires in the harness. Not hard at all to replace/repair the bad wires.
The ECU provides a negative to the fuel pump when ever one of three conditions are met. 1- when key is turned to on - pump will run 1-2 seconds, 2- whenever the starter is turning engine over 3- whenever the engine is running over XXX RPM's There is a link on this site to Brad Anders D-jet info. look under 914 info at the top of the page. As an ASE master tech, you will probably understand a lot of it. Tom |
Lo-Fi Version | Time is now: 14th May 2024 - 09:24 PM |
