Long accelerator cable, Where to get? |
marks914 |
Jan 25 2005, 03:37 PM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
Anyone kow who makes a longer accelerator cable for a 914?
Thanks Mark |
Dr Evil |
Jan 25 2005, 03:41 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Search for Terry Cable. They will make what ever you want.
jim_hoyland |
Jan 25 2005, 03:59 PM
Get that VIN ? Group: Members Posts: 9,303 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Just got a Terry cable from Pelican PArts; very fast delivery too !
Dr Evil |
Jan 25 2005, 04:02 PM
Jim,
why not just buy it from Terry directly? Was the bird inexpesive? |
marks914 |
Jan 25 2005, 06:48 PM
Cool, Thanks.
I can just call pelican and they will order it up for me? The cable is just too short for the V8. If anyone has pics of their v8 throttle setup I would be interested. Mine works OK, its just not as good as it could be. Thanks Mark |
tesserra |
Jan 25 2005, 07:41 PM
Member Group: Members Posts: 210 Joined: 26-March 03 From: Lafayette CA Member No.: 479 |
How did you run your cable?
I think a better way to run the cable is to the front of the engine with the cable coming across the front of the engine. (stock 914 cable) Then you use a bellcrank set up to change the motion to go from front to rear. This is also good because the throw of the 914 throttle is not enough or just barely enough to open most 4 bbl carbs all the way. With a bellcrank you could adjust the distance from the pivot point to get WOT with the 914 pedal. They sell a bellcrank setup in the Jegs catalog, its with the carbs. No, I haven't done this, but if I knew about it it would have saved me a big PITA and would proboably work better than the Terry cable set up I have. George |
Lo-Fi Version | Time is now: 21st May 2024 - 12:33 AM |
