Replacing rear main seal, What parts along the way can't be reused? |
rjames |
Sep 1 2014, 05:48 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I replaced the clutch and flywheel last year and the rear main seal, but it looks like it's leaking again.
As part of the task of removing the pressure plate, clutch and flywheel to get to the seal, what parts can't I use again? Do I need a new felt washer? What else? |
rjames |
Sep 1 2014, 08:43 PM
Cap'n, I'm looking at the list of items in Pelican's clutch kit and I don't see a lock washer listed. Are you referring to the 'metal crush gasket' on their list?
Pelican's list of clutch replacement parts: New Pressure Plate New 911 Clutch Disc New Throw-out Bearing New Pilot Bearing and Felt Ring 2 Throw-out Bearing Guide Clips New Throw-out Fork Bushing New Flywheel O-Ring New Flywheel Bolts New Flywheel Metal Crush Gasket |
Lo-Fi Version | Time is now: 17th May 2024 - 03:02 PM |
