1973 1.7 fuel pressure issue |
metalmorphosis |
Sep 1 2014, 07:43 PM
Member Group: Members Posts: 90 Joined: 31-July 12 From: winston-salem nc Member No.: 14,743 Region Association: South East States |
First off like the title says I have a 73 1.7 car w the fuel injection still in place. The pump is 12-13 years old, I put it on when I bought the car as it didn't have the correct one on it when I bought it. Less than 2yrs ago I had the tank boiled out and lined by a local radiator shop and I replaced ALL lines w new stainless and rubber throughout.
So a couple weeks ago I tried to start my car and it wouldn't start. I had driven it just a few days earlier but now I've got nothing. After playing with some starter fluid I find it will run on that so I figure it has to be an issue w fuel pressure. So I assume maybe the fuel filter is somehow clogged. After replacing it still nothing so I borrow a friends pressure gauge and start lookin for pressure but still nothing. So in the process of trying different things I find that if I pinch off the return line that y's off the engine supply line off the pump I have 70-80 lbs before the regulator. But when I unpinch that return line I have no pressure. I also noticed that w that line pinched I still had no pressure after the regulator so I took it out of the system and the car starts and runs just has too much pressure. But when that return line is unpinched it goes back to not having any fuel pressure. Now that I've been studying all this stuff it doesn't make since to me how it builds any pressure to the fuel rails with the supply line splitting as soon as it comes outta the pump and returning to the tank. Although I assume it has to be plumbed correctly cause it has ran for just under 2 yrs like this. Hopefully I've described things good enough so what do y'all think? Thanks Gabe |
Lo-Fi Version | Time is now: 10th May 2024 - 12:51 AM |
