Nearly naked teen! |
bondo |
Jan 25 2005, 04:39 PM
Ha, made ya look! I say nearly because it still has paint (which I guess would be equivalent to lingerie), rust holes (tattoos?), and jackstands (high heels). (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
I have taken off pretty much everything, but I have a few questions... What have I probably forgotten to take off? (I did find and remove the plugs for the ski rack mounts) Is there any way to remove the windshiled trim clips without destroying them? Is there any way to save the sticker on the door jamb? There appear to be caps on the top sides of the holes where thr trailing arm mounts. Should I remove those? Here's pic 1: Attached image(s) |
bondo |
And the second pic: (last for now)
Aaron Cox |
Jan 25 2005, 04:40 PM
nice... keep it gween (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
bondo |
Jan 25 2005, 04:42 PM
I've decided to go for the full monty and soda blast it.. so I can go with my first choice of yellow. (yellow is faster)
914GT |
Jan 25 2005, 04:54 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
I saved my door jamb tag and reattached it after painting. I think I warmed it up with a head gun and carefully slipped a razor blade under it. You could probably remove and reuse the windshield trim clips, but I don't think they are that expensive so new would be better. I kept my original clips on but it was a pain stripping paint around them.
John |
Jan 25 2005, 05:02 PM
There used to be 6 plugs (3) on each side under the roll bar above the engine lid.
Yes, remove the 6 plugs covering the tops of the trailing arm bolts. I like to soak those with penetrating oil before removal. When you are done painting, put the plugs back as they keep crap out of the holes. (Or you could do what I did and through bolt the trailing arm bolts and put nuts on top.) |
skline |
Jan 25 2005, 05:23 PM
I think that is what I am going to do also. One of my caps is missing anyway and I think one of the bolts is stripped. |
jwalters |
Jan 25 2005, 05:30 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
Do you know where that " Head Gun " has been?? Did you wash afterwards??? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Yea go yello--green is puke (IMG:http://www.914world.com/bbs2/html/emoticons/icon8.gif) |
Joe Ricard |
Jan 25 2005, 06:39 PM
I fall for that naked teen thing everytime. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Then there is the "head gun" to majically get the door jamb sticker off. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) Hey Jwalters is that a ZIPPER ON YOUR STRIPPER? cool avatar man. |
sgomes |
Jan 25 2005, 09:03 PM
Electric Member Group: Members Posts: 815 Joined: 6-May 04 From: Campbell, CA Member No.: 2,029 |
I'm just checking... Is it a bad sign that when I saw the subject I actually pictured a bare-metal 914? (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
kafermeister |
Jan 25 2005, 09:09 PM
Senior Member Group: Members Posts: 778 Joined: 20-January 03 From: Cincinnati/Northern KY Member No.: 174 |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
I did the same thing. We're a messed up bunch. |
markb |
Jan 25 2005, 09:10 PM
I want a head gun!! 'Course I'd probably never get anything done. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
We really need a perv smilie. |
swood |
Jan 25 2005, 09:42 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Wow that's a bold move! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Any chance you could post a few pics of the areain the trunk just on the other side of the steering wheel? I'm interested in what penetrations there are through the body under the air vent stuff.
swood |
Jan 25 2005, 09:46 PM
Here?
McMark |
Jan 25 2005, 09:47 PM
Get new windshield trim clips, otherwise you'll watch helplessly as it flies off when you're cruising down the freeway. They are a one time use item. You can actually order new door jamb stickers from the dealer. There are subtle differences with the replacements, but IMHO they're good enough for everyone but the CWs. That's what I plan for my Aubergine car.
bondo |
Jan 25 2005, 09:58 PM
Hereyago!
From the front: Attached image(s) |
bondo |
Jan 25 2005, 09:59 PM
From the back:
bondo |
Jan 25 2005, 10:02 PM
Are they reasonably priced? My sticker is kind of weathered and probably not worth saving, now that I think about it. |
swood |
Jan 25 2005, 10:17 PM
Coolio man! Now I can figure out where the H20 is coming in.
(IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
Mr.C |
Jan 25 2005, 10:34 PM
Easy does it Group: Members Posts: 611 Joined: 31-December 02 From: Central Cal Member No.: 61 Region Association: None |
Ok I'll ask it, why did you choose blastin as opposed to chem strip? Is it cheaper? Better? I'm still on the fence on what I'm gonna do when it comes time.
Lo-Fi Version | Time is now: 16th May 2024 - 07:21 PM |
