MPS Adjustment, It helps to have the right tools |
Mblizzard |
Sep 2 2014, 08:00 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
I post this only because I struggled to find the proper tools to adjust my MPS after going to a 2056. While I was able to make adjustments using standard tools, I could never get it exactly right. I asked several people about where I could get the right tools and could not find them. It is likely that this is well known to everyone but me, but I finally found what I needed at Tangerine Racing.
It is such a simple tool but without it you can't really be sure you are adjusting only one of the screws without changing the other one. So once again Chris is the man that can put the right tool in your hand. I have been close on the adjustment many times only to mess it up trying one more small change. If you are playing with your MPS just get one of the MPS tuning kits from Chris it will make your life much easier. |
DRPHIL914 |
Sep 3 2014, 09:39 PM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I believe its called a wavetec . A member here did mine and his own but we both found those settings to be too lean (scottinnh) and so using Anders as the guide then gradually used my a/f meter to get it in good running . As I took it a bit more rich the idle smoothed out and now runs great. If you get a hunting its either vac leak or the mps is set too lean(if all other items are previously sorted)
Lo-Fi Version | Time is now: 27th May 2024 - 02:45 AM |
