914-6 Engine Wiring Harnesses, Conversion or Stock, Plug & Play |
IronHillRestorations |
Jan 25 2005, 10:58 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've just taken recipet of color coded wiring, PVC insulating, and heat shrink tubing for 914-6 engine wiring harnesses. I can make a stock or custom harness for your application, or sell you a kit to make your own. Some core connectors are required. If you have a internally regulated alternator you may be able to eliminate the relay board and brackets, for a cleaner less cluttered engine bay. The black PVC insulating jacket and heat shrink tubing makes for a very OEM appearance.
If you are going through all the trouble of putting a flat six in your car, give it a professional looking wiring harness, not one covered with electrical tape! All connections are crimped AND soldered! >>>>Price Edit as of Sept 14, 2017 Custom made harnesses start at $325 plus your core CDI box plug and boot. Custom harnesses available and depending on the relay board and circuits required. The price of Porsche factory connectors and boots has really gone up. A factory 14 pin male connector to plug directly into the 14 pin female connector in your 914-4 harness (if you have removed the relay board) is $48 A new rubber grommet where harness goes through the rear of the 914-6 engine tin is $8.50 E-mail me at: perry.kiehl@hotmail.com Or call 731 733-8482 Perry Kiehl 914 Network |
sixnotfour |
Feb 5 2009, 05:03 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
very nice, what does that harness cost approx ?
Jan 9 2010, 02:14 PM
very nice, what does that harness cost approx ? Jeff, A 914-6 Harness with battery cable, ignition shielding, and all stock circuitry is $390 plus $11 for flat rate USPS box. If you don't need the cold start and throttle pull down circuits you can deduct $30, if you don't need the integral battery cable you can deduct another $35. Does not include any boots. The factory boot and connector body for the 3 pin CD box is NLA. Porsche has replaced the 3 pin boot with a later part and it is over $80!!! So you need to send me one from your 911 harness, or contact me about a used one. PK |
Lo-Fi Version | Time is now: 18th May 2024 - 05:16 AM |
