Rear Caliper Rebuild, "How-To Thread" |
Eric_Shea |
Jan 25 2005, 11:07 PM
In an earlier thread I was asked to write a “How-To” thread on the rear caliper rebuild. I had to get some pictures together before this made sense.
I’m starting this thinking you’ve already gotten them off the car and you understand how to reinstall them and bleed your brakes. This is all about the caliper rebuild. This is also about a “top-end” caliper rebuild. If your caliper is leaking through the handbrake lever I would consider getting a new core at least. Why? Rebuild kits are around $22.00. Handbrake rebuild kits are around $50.00. Now you’re in it for close to $80.00 with shipping etc. A rebuildable core should go for $20-$40 bucks… as these get scarce you may want to reconsider but currently they’re not too scarce. This job is not fun and it’s not all that easy. It’s not too tough either, it just requires some mechanical ability, patience, special tools and some “tricks of the trade”. Yes, I rebuild these so I’m either loosing customers or gaining customers by writing this (I’m obviously not too concerned). Follow the thread. If it’s something you want to tackle then dive in. If not, you know where to go. Here are some of the tools you’ll need: Dental Pick T27 Torx Driver (early single bleeder style) Torque Wrench 4mm Hex key Small and Large Locking Pliers Brake Grease Brake Cleaner Large Screwdriver Small Wire Brush 13mm Socket 11mm Deep Well Socket (to press the spring and cover into the inner caliper half) 11mm Socket MAP Torch Air Wrench Pistol Grip Clamp Brake Caliper Hone Hand Drill Two Rear Caliper Rebuild Kits from Your Favorite Vendor (they must include all seals) 7mm Wrench (for the bleeder valve. I prefer to use a small pair if locking pliers though…) Here’s the “How-To” 1. Drain it. You’ll want to get all the fluid out of these before you dig into the task at hand. As mentioned above, take a pair of locking pliers and snug them down on the bleeders. Most are stuck and this is the only way to go. The 7mm wrench will rarely do the trick. Once you get them off, try to blow some air through them. 2. I like to mount these in a vise before I start the dismantling process. Next I start with the caliper half bolts. These are 11mm bolts on the later style (dual bleeder) or T27 Torx bolts on the early calipers (single bleeder). The early calipers have 11mm nuts on them. These will seem impossible to remove. Here’s where the MAP torch comes into play. Don’t worry too much about heating these puppies up. First of all, brakes get hot. Second, you have new seals in your rebuild kits. You just don’t want to heat up the parking brake area because as discussed earlier, that’s another $50.00 in parts and another rebuild. Heat the bolts and use your air wrench to hammer these off. Split the caliper and remove the inner seals. While you’re at it, remove the dust boots and clamps using the dental pick. Attached image(s) |
Eric_Shea |
Jan 25 2005, 11:20 PM
9. Install the piston seals from your kit. They don’t seem like they’ll fit but keep pressing them around and use that handy dental pick to position them. Soon enough they’ll drop right in the groove. I lube them up with brake fluid before I install them (as I do with all the seals).
10. Install the adjusters. Clean them up with the brake cleaner and the wire brush first. Remove the old seals and install the new seals from your rebuild kit. The outer adjuster simply pushes right in (use brake fluid as a lube on the seal). Install the 13mm nut and then reinstall the clip. The inner adjuster is a bit more complicated (remember… you wanted to do this). Use the brake caliper grease and load up the hole at the base of the adjuster where the famous “sausage” goes. Insert the sausage and spread some of the extra grease on the gear. Push the adjuster into position and make sure it drops fully into place. Place the spring over the adjuster and follow it up with the hat. Place the clip over the hat and your ready for the real fun stuff. Use the 11mm deep well socket and use the “Pistol Grip Clamp” to press the assembly in to place. Dental pick time again; use the pick to press the clip back into the groove. Once you know for sure that it’s snapped into place, release the clamp. Install the adjuster gear and use some new adjuster covers for the inner halves. Attached image(s) |
Lo-Fi Version | Time is now: 24th May 2024 - 11:02 PM |
