Seat slides backward, seat adjustment |
Mike1981 |
Sep 10 2014, 07:30 AM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello
I just picked up a 1970 914 I was hoping for some advice please I seems as if the clutch pedal must be depressed all the way to the floor to avoid grinding However the seat is all the way back to the firewall When I move the seat forward my legs can easily depress the pedal as well as the reach to the gearshifter is better. The only problem I have is when pushing in on the clutch the seat detaches from its setting and slides all the way back I took the seat out oiled the rails and it slides easily by hand Once I put pressure on it, the seat will again snap out of it setting and slide back Has anyone had this happen Could anyone offer a solution? Thanks Mike |
Mike1981 |
Sep 16 2014, 05:36 PM
Hello
Well I checked for the clutch tube movement did not see any. I crawled under the car Grabbed the clutch cable with a set of vice grips to stop it from spinning While I tightened the 2 nuts on the opposite side of the shifting fork. I only have 3 more threads left Jumped inside and the clutch feels much better. I am still having trouble with the seat. It is fine until pulling out of 1st the torque that throws me back overcomes the spring on the right side adjuster of the seat. I took the seat out again and it seems to operate correctly I replaced the seat and it slides up and back fine, it also locks into position. But every time I shift and feel the cars torque the seat spring gives way and I slide back. My foot becomes unsteady on the clutch and the car lurches Does anyone know of a spring replacement number or model I could buy and put into my seat? Thanks Mike |
bdstone914 |
Sep 17 2014, 08:47 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hello Well I checked for the clutch tube movement did not see any. I crawled under the car Grabbed the clutch cable with a set of vice grips to stop it from spinning While I tightened the 2 nuts on the opposite side of the shifting fork. I only have 3 more threads left Jumped inside and the clutch feels much better. I am still having trouble with the seat. It is fine until pulling out of 1st the torque that throws me back overcomes the spring on the right side adjuster of the seat. I took the seat out again and it seems to operate correctly I replaced the seat and it slides up and back fine, it also locks into position. But every time I shift and feel the cars torque the seat spring gives way and I slide back. My foot becomes unsteady on the clutch and the car lurches Does anyone know of a spring replacement number or model I could buy and put into my seat? Thanks Mike Mike, I have replacement rails. Which one is it? With or without the handle? Bruce |
Mike1981 |
Sep 17 2014, 05:04 PM
Hello Well I checked for the clutch tube movement did not see any. I crawled under the car Grabbed the clutch cable with a set of vice grips to stop it from spinning While I tightened the 2 nuts on the opposite side of the shifting fork. I only have 3 more threads left Jumped inside and the clutch feels much better. I am still having trouble with the seat. It is fine until pulling out of 1st the torque that throws me back overcomes the spring on the right side adjuster of the seat. I took the seat out again and it seems to operate correctly I replaced the seat and it slides up and back fine, it also locks into position. But every time I shift and feel the cars torque the seat spring gives way and I slide back. My foot becomes unsteady on the clutch and the car lurches Does anyone know of a spring replacement number or model I could buy and put into my seat? Thanks Mike Mike, I have replacement rails. Which one is it? With or without the handle? Bruce Hello Bruce It is the one with the handle Thanks Mike |
Lo-Fi Version | Time is now: 17th May 2024 - 05:13 PM |
