Seat slides backward, seat adjustment |
Mike1981 |
Sep 10 2014, 07:30 AM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello
I just picked up a 1970 914 I was hoping for some advice please I seems as if the clutch pedal must be depressed all the way to the floor to avoid grinding However the seat is all the way back to the firewall When I move the seat forward my legs can easily depress the pedal as well as the reach to the gearshifter is better. The only problem I have is when pushing in on the clutch the seat detaches from its setting and slides all the way back I took the seat out oiled the rails and it slides easily by hand Once I put pressure on it, the seat will again snap out of it setting and slide back Has anyone had this happen Could anyone offer a solution? Thanks Mike |
76-914 |
Sep 17 2014, 08:38 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Drill and pin it. Your the only driver, right?
Mike1981 |
Sep 18 2014, 05:48 AM
Drill and pin it. Your the only driver, right? That is not a bad idea, however I do like to slide the seat back to get in and out of my car If I pin the position I would have to contort my legs to get into the seat. As time goes by this becomes more painful Thanks for the input Mike |
Lo-Fi Version | Time is now: 17th May 2024 - 05:05 PM |
