WTB 2.7 pistons and cylinders, CIS |
JStroud |
Sep 12 2014, 08:36 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Started tearing down my 2.7 for a rebuild, the cylinders are a combination of mahle and KS. (IMG:style_emoticons/default/confused24.gif) they're also Alusil and not in very good shape.
So, I'm looking for a GOOD used set, with nickasil cylinders and matched CIS pistons, or a reasonably priced new set. 2.7 with CIS. Anyone got some laying around? Thanks, Jeff |
Luke M |
Sep 12 2014, 09:14 AM
Senior Member Group: Members Posts: 1,368 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Hi Jeff,
I have some 2.7 cis p/c's laying around. I'll dig them out later today and look them over. I'll take some pics of them too. If you want pm me on this. |
koozy |
Sep 12 2014, 05:14 PM
Senior Member Group: Members Posts: 646 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
I also think I have a known good set. Let me know if you need to consider a second set and I will pull them for photos.
JStroud |
Sep 13 2014, 08:45 AM
Thanks for the replies, Edited the first post, looking for a complete set with nickasil cylinders and matching CIS pistons.
My understanding is the alusil cylinders can't be reused, or honed. Thanks, Jeff |
Mark Henry |
Sep 13 2014, 06:39 PM
Peashooter |
Sep 19 2014, 02:43 PM
Member Group: Members Posts: 163 Joined: 17-December 11 From: SW Ohio Member No.: 13,903 Region Association: None |
I have a set of P/C's for a 2.7 CIS. They are in great shape. PM me for photos if interested. I put a euro set in my engine.
rick 918-S |
Sep 19 2014, 05:29 PM
Hey nice rack! -Celette Group: Members Posts: 20,402 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I had a 928 block bored out from 4.7 to 5.0. The block is solid alusil. The trick is the pistons have to be made to run in alusil bores or they will gall the cylinders. Pistons for alusil bored have a special iron coating as I understand. (or some kind of surface treatment) My only option was 32 valve 928 pistons notched for 16 valve heads. Now the 911 may have piston options the 928 guys don't have due to popularity.
flmont |
Sep 19 2014, 09:12 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
I rebuilt a 3.0 a few years back and they had the Alusil P/C's,...I did the ball honing method finished with a lite scotch brite pad ,...the rings must be for the Alusil's Cyl. and my engine and had great comp. and leak dwn numbers,... FM
Peashooter |
Sep 22 2014, 07:53 AM
Pics sent!
JStroud |
Sep 22 2014, 06:30 PM
rudedude |
Sep 24 2014, 07:44 AM
Senior Member Group: Members Posts: 508 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
The alusil cylinders can be nikasil treated and honed for "normal" pistons.
Ask Len Hoffman. |
JStroud |
Sep 24 2014, 11:11 AM
I have found that out in my research, however I'm running CIS, I need CIS pistons.
Looks like I found a set, search is over. Thanks Bill. Jeff |
Lo-Fi Version | Time is now: 18th April 2024 - 01:00 PM |
