Sand blasting, Harbor freight |
spunone |
Jan 26 2005, 05:00 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Has anybody tried to use one of those H F 20 lb sand blasting units to clean up there Hell Hole and inside Floor? Or is it like throwing sand at it from your hand?
vortrex |
Jan 26 2005, 05:11 PM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
all depends on what size compressor you are using to drive it. blasting takes a lot of air, but it does clean up rust nicely.
Randal |
Jan 26 2005, 05:12 PM
I have one and like it. You'll need a good compressor to drive the unit.
Only PITA is that the sand runs out pretty quickly. And it is a messy process, unlike a bead blaster in a big closed work area. |
spunone |
Jan 26 2005, 05:19 PM
Thanks I have a 5or 10 hp air com .What type of media works best sand or????
sanman |
Jan 26 2005, 05:20 PM
Leaving California Group: Members Posts: 341 Joined: 17-June 04 From: Houston, TX Member No.: 2,219 Region Association: None |
yes! I did my car, you will have sand everywhere. Strip, scrape, and sand as much as you can get off before blasting. It is rough with a small to medium compresor.
I used a fine blasting sand from ACE. It was 4bucks for a 50lb bag. |
Mueller |
Jan 26 2005, 05:23 PM
don't ever drive your car with the air-cleaner off...the sand will come out of the cracks and seams for years on down the road.....BTDT...it's a PITA and next time I'll pay someone to blast it.........
Britain Smith |
Jan 26 2005, 05:33 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
That reminds me Mike...I need to get your blaster back to you. I am putting things back together and don't need it anymore.
-Britain |
SLITS |
Jan 26 2005, 08:05 PM
Sand removes metal.....glass bead removes the rust only (which on a teener is all the metal (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) )
Lo-Fi Version | Time is now: 20th May 2024 - 11:23 PM |
