FS Replated Silver zinc parts |
bdstone914 |
Sep 14 2014, 10:05 PM
bdstone914 Group: Members Posts: 4,507 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Door strikers. Late type $30 a pair. 3 Pair available
Door latches that go inside the door $75 a pair. 4 pair available Front turn signal bucket clamps $20 per set, 6 available Steel headlight pivots sets. $60, 3 sets set consists of two outer, two inner and four backing plates Late engine blower motor clamps $15 , 2 available late blower clamp for plastic spliter $10. 2 available Lug nut sets of 16, $30 per set, 2 sets available Gas tank charcoal canister straps $20, 4 available Horn mount bracket $10 each 3 available Fuel injection rails and injector clamps. Rails $20 per set. 2 sets available injector clamps 7 sets available $20 per set. $30 for a set of rails and clamps. Attached thumbnail(s) |
bdstone914 |
Sep 14 2014, 10:13 PM
More pictures
madmax914 |
Sep 18 2014, 10:05 AM
Member Group: Members Posts: 204 Joined: 16-February 14 From: Salem, Oregon Member No.: 17,007 Region Association: Pacific Northwest |
Do you still have a pair of inner and outer steel headlight pivots?
bdstone914 |
Sep 18 2014, 12:28 PM
Kansas 914 |
Sep 19 2014, 08:37 AM
Hi Bruce - I just sent a PM for a set of rails and clamps, |
02loftsmoor |
Sep 19 2014, 09:22 AM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
bdstone914 |
Sep 19 2014, 11:22 AM
More pictures do you do exchanges? I like pretty shiny things,, like the brake canister strap.. i'm working on my wish list I can but you would need to get cleaned parts to me soon. I do not do a silver run often. Putting together a run of gold parts to go in soon. Bruce |
02loftsmoor |
Sep 19 2014, 03:05 PM
More pictures do you do exchanges? I like pretty shiny things,, like the brake canister strap.. i'm working on my wish list I can but you would need to get cleaned parts to me soon. I do not do a silver run often. Putting together a run of gold parts to go in soon. Bruce nuts this is a long term thing, i have to save my lunch money up |
Mblizzard |
Sep 19 2014, 03:59 PM
Bruce your killing me! Put me down for a set of rails and clamps. I will need you to write a note to my wife explaining how you intentionally play on our weakness with bright shinny things.
bdstone914 |
Sep 19 2014, 05:52 PM
Bruce your killing me! Put me down for a set of rails and clamps. I will need you to write a note to my wife explaining how you intentionally play on our weakness with bright shinny things. Get an extra set of injector clamps and let her make ear rings out of them. (IMG:style_emoticons/default/cheer.gif) |
Mblizzard |
Sep 19 2014, 06:20 PM
Bruce your killing me! Put me down for a set of rails and clamps. I will need you to write a note to my wife explaining how you intentionally play on our weakness with bright shinny things. Get an extra set of injector clamps and let her make ear rings out of them. (IMG:style_emoticons/default/cheer.gif) That's a great diversification for your business. But you may have to add a divorice service also. PM me a total. Hold the earrings and divorice. |
bdstone914 |
Sep 19 2014, 06:47 PM
More pictures do you do exchanges? I like pretty shiny things,, like the brake canister strap.. i'm working on my wish list Zinc is not a good choice for plating. It is only good for 400 degrees which the pipes get hotter than that. Most shells are so rusted they will not look good. Better to balst them and spray the shells with high temp paint. |
bdstone914 |
Oct 5 2014, 12:08 PM
Bump for added parts
bdstone914 |
Nov 6 2014, 11:01 AM
Still have many plated parts in addition to those pictured.
Ask if you need it. |
bdstone914 |
Nov 6 2014, 07:00 PM
More plated goodies.
Powdercoated early metal gauge cluster bezel $25 striker plates $15 transmission plate $25 gas cap $20 front latch $25 tire hold down with bolt $15 strut washers $ 20 pair Attached thumbnail(s) |
bdstone914 |
Dec 15 2014, 08:43 PM
Bump, still have most of these parts available
Door strikers. Late type $30 a pair. 3 Pair available Door latches that go inside the door $75 a pair. 4 pair available Front turn signal bucket clamps $20 per set, 6 available Steel headlight pivots sets. $60, 3 sets set consists of two outer, two inner and four backing plates Late engine blower motor clamps $15 , 2 available late blower clamp for plastic spliter $10. 2 available Lug nut sets of 16, $30 per set, 2 sets available Gas tank charcoal canister straps $20, 4 available Horn mount bracket $10 each 3 available Fuel injection rails and injector clamps. Rails $20 per set. 2 sets available injector clamps 7 sets available $20 per set. $30 for a set of rails and clamps. |
Lo-Fi Version | Time is now: 18th April 2024 - 05:24 PM |
