WTB late engine bar hardware, Bolts? Plates? Please? |
TargaToy |
Sep 15 2014, 07:38 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
Converting my 72 to side shift. I've got the bar but all the itty bitty mount parts went away with the donor car.
I'm looking for the top "plates" that allow the bar to hard mount to the car as well as any associated bolts, washers, nuts. Thanks. |
bdstone914 |
Sep 15 2014, 08:01 PM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Converting my 72 to side shift. I've got the bar but all the itty bitty mount parts went away with the donor car. I'm looking for the top "plates" that allow the bar to hard mount to the car as well as any associated bolts, washers, nuts. Thanks. I have the plates. The bolts are 10 mm x 100 mm. I might have some used ones. Not to hard to find new. The small brackets attach to the body with 8 mm x 20mm bolts. Do you have the two brackets that bolt to the engine and motor mounts? |
TargaToy |
Sep 15 2014, 08:44 PM
I have the brackets that mount to the motor and will just have to get the rubber spacers at some point. If the bolts/nuts/washers are just hardware store items, I guess what I'm in need of is the plates that the ends of the bar bolt to at each side of the engine bay. Part #11 on this diagram.
BTW, are the "bolts" that run up through the bar to the motor mounts threaded dowels with nuts on either end? |
bdstone914 |
Sep 15 2014, 09:49 PM
I have the brackets that mount to the motor and will just have to get the rubber spacers at some point. If the bolts/nuts/washers are just hardware store items, I guess what I'm in need of is the plates that the ends of the bar bolt to at each side of the engine bay. Part #11 on this diagram. BTW, are the "bolts" that run up through the bar to the motor mounts threaded dowels with nuts on either end? The motor mounts are one piece with a stud coming out top and bottom.. |
carl k |
Sep 15 2014, 11:07 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
I've got those parts. I'll send you a PM. Carl K. |
koozy |
Sep 17 2014, 12:00 AM
Senior Member Group: Members Posts: 648 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
After the original poster gets his parts I could use a pair too. Bruce, do you have newly plated ones?
DblDog |
Sep 17 2014, 05:45 AM
Member Group: Members Posts: 164 Joined: 8-February 05 From: San Rafael, CA Member No.: 3,578 Region Association: Northern California |
I have a set of plates, recently plated...will post a pic later this am
DblDog |
Sep 17 2014, 02:53 PM
New mount plates...
$35/ shipped |
mikea100 |
Sep 20 2014, 01:33 PM
Member Group: Members Posts: 180 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States |
I have a pair. $10 to cover shipping and PayPal fees or free local pickup.
Lo-Fi Version | Time is now: 4th May 2024 - 05:11 PM |
