WTB late engine bar hardware, Bolts? Plates? Please? |
TargaToy |
Sep 15 2014, 07:38 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO- Group: Members Posts: 692 Joined: 26-March 10 From: DelMarVa Peninsula Member No.: 11,509 Region Association: MidAtlantic Region |
Converting my 72 to side shift. I've got the bar but all the itty bitty mount parts went away with the donor car.
I'm looking for the top "plates" that allow the bar to hard mount to the car as well as any associated bolts, washers, nuts. Thanks. |
bdstone914 |
Sep 15 2014, 08:01 PM
bdstone914 Group: Members Posts: 4,526 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Converting my 72 to side shift. I've got the bar but all the itty bitty mount parts went away with the donor car. I'm looking for the top "plates" that allow the bar to hard mount to the car as well as any associated bolts, washers, nuts. Thanks. I have the plates. The bolts are 10 mm x 100 mm. I might have some used ones. Not to hard to find new. The small brackets attach to the body with 8 mm x 20mm bolts. Do you have the two brackets that bolt to the engine and motor mounts? |
TargaToy |
Sep 15 2014, 08:44 PM
I have the brackets that mount to the motor and will just have to get the rubber spacers at some point. If the bolts/nuts/washers are just hardware store items, I guess what I'm in need of is the plates that the ends of the bar bolt to at each side of the engine bay. Part #11 on this diagram.
BTW, are the "bolts" that run up through the bar to the motor mounts threaded dowels with nuts on either end? |
bdstone914 |
Sep 15 2014, 09:49 PM
I have the brackets that mount to the motor and will just have to get the rubber spacers at some point. If the bolts/nuts/washers are just hardware store items, I guess what I'm in need of is the plates that the ends of the bar bolt to at each side of the engine bay. Part #11 on this diagram. BTW, are the "bolts" that run up through the bar to the motor mounts threaded dowels with nuts on either end? The motor mounts are one piece with a stud coming out top and bottom.. |
Lo-Fi Version | Time is now: 24th May 2024 - 06:21 PM |
