? about 6V Ford Relay |
AvalonFal |
Sep 17 2014, 04:11 PM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
Got a 6V, 3 post Ford relay from ebay for my "74 2.0L Wired it up per the many threads on the subject on this and other boards.
My understanding of its operation is that 1 large post always has 12V (from battery) and the other 2 posts (small "S" and the other large one back to the starter) have 12V when the key is ON. Is this correct?? I'm not getting 12V at the large post that runs back to the starter. I'm thinking the Ford relay is defective. Any thoughts from Ford relay users?? Paul |
busmech |
Sep 17 2014, 08:04 PM
Member Group: Members Posts: 68 Joined: 12-April 09 From: Daly City Ca Member No.: 10,258 Region Association: Northern California |
The 2 small terminals are for the coil. One needs power and the other one needs to go to ground. The power one is from the start circuit so it will only be on when you turn the key to start.
AvalonFal |
Sep 17 2014, 08:18 PM
The 2 small terminals are for the coil. One needs power and the other one needs to go to ground. The power one is from the start circuit so it will only be on when you turn the key to start. It's a 3 post relay, so there's only 1 small post. It's grounded through the mounting bracket. Paul |
Lo-Fi Version | Time is now: 15th May 2024 - 05:45 PM |
