? about 6V Ford Relay |
AvalonFal |
Sep 17 2014, 04:11 PM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
Got a 6V, 3 post Ford relay from ebay for my "74 2.0L Wired it up per the many threads on the subject on this and other boards.
My understanding of its operation is that 1 large post always has 12V (from battery) and the other 2 posts (small "S" and the other large one back to the starter) have 12V when the key is ON. Is this correct?? I'm not getting 12V at the large post that runs back to the starter. I'm thinking the Ford relay is defective. Any thoughts from Ford relay users?? Paul |
busmech |
Sep 17 2014, 08:18 PM
Member Group: Members Posts: 68 Joined: 12-April 09 From: Daly City Ca Member No.: 10,258 Region Association: Northern California |
Depending on the coil design it might need to be grounded at the other small terminal. Check for resistance from the terminal that the start feed is connected and to the mounting bracket, it might be grounded through the bracket. If not then it the 2 small terminals would be + and -. sorry if this is confusing but I looked up wiring diagrams an some aplications the 2nd terminal runs to the coil.
http://www.bing.com/images/search?q=ford+s...selectedIndex=2 Sorry if the other post is wrong, but you need pos and ground for the coil. |
Lo-Fi Version | Time is now: 15th May 2024 - 06:19 AM |
