? about 6V Ford Relay |
AvalonFal |
Sep 17 2014, 04:11 PM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
Got a 6V, 3 post Ford relay from ebay for my "74 2.0L Wired it up per the many threads on the subject on this and other boards.
My understanding of its operation is that 1 large post always has 12V (from battery) and the other 2 posts (small "S" and the other large one back to the starter) have 12V when the key is ON. Is this correct?? I'm not getting 12V at the large post that runs back to the starter. I'm thinking the Ford relay is defective. Any thoughts from Ford relay users?? Paul |
AvalonFal |
Sep 17 2014, 09:29 PM
Any description of why you want to use a relay to run a relay would be helpful. My willingness to believe is high, my understanding is low. There are 25+ threads on this board regarding adding a relay to the starting sequence. My understanding is that the additional relay requires less current and will reduce the load on the ignition switch (prolonging its useful life) and help in "hot start" situations.. Paul Jump a wire straight from the battery to the small post, if it clicks (not hooked up) or turns the starter (hooked up) then the problem is elsewhere I will do so in the AM. Paul |
Lo-Fi Version | Time is now: 15th May 2024 - 01:18 AM |
