New rear PMB alloy calipers. Now no break pressure |
Downerman |
Sep 17 2014, 04:57 PM
Member Group: Members Posts: 168 Joined: 23-April 09 From: Monterey County, California Member No.: 10,296 Region Association: None |
OK, OBVIOUSLY no negative to the calipers. Here's the deal..... removed the 911 rear calipers (well for that matter the entire swing arms) but I just let the brake fluid lines hang and drain into jars. Finally got my swing arms mods done and now putting on the new calipers. Filled the brake resevoir up and had all 4 wheels off the car. Used my handy dandy brake sucker pump and had fluid running to all four bleeders on the rear (2 each for a caliper) and then did the fronts. Had to refill a couple of times because I was pulling some darker fluid until it was clear. Went into the cab and hit the breaks. Nothing.... I mean NADA. Pumped like a 100 times to no avail.
RE-DID the entire process again. NADA and I mean nothing. So, I'm wondering if my master has gone south in this time line?? and why?? Seems the only logical answer at this point. Anyone have any ideas? Dave |
rgalla9146 |
Sep 22 2014, 06:43 PM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
......... you would have had your solution much sooner if you mentioned your calipers were at the south pole.
oh..... and now the car has "brakes" not "breaks" |
Lo-Fi Version | Time is now: 18th May 2024 - 07:54 AM |
