| jim_hoyland |
Sep 19 2014, 07:08 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,962 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
What is the best way to get enough slack at the eBrake pivot yoke so that the cable and pin can be reinstalled ?
It was hard to remove I didn't loosen the eBrake cables at the firewall nor the caliper Attached image(s)
| bdstone914 |
Sep 19 2014, 07:50 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,215 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
You can attach the cable to the handle before you bolt it to the long. You may be able to pull to handle enough to get it back on the stud. Otherwise you will have to loosen the cables at the firewall then readjust after installing the handle.
| jim_hoyland |
Sep 19 2014, 07:53 AM
[quote name='bdstone914' date='Sep 19 2014, 06:50 AM' post='2087999']
You can attach the cable to the handle before you bolt it to the long. You may be able to pull to handle enough to get it back on the stud. Otherwise you will have to loosen the cables at the firewall then readjust after installing the handle. [/ That worked ! Thanks. I have the new lever mounted and just need to take up some slack at the firewall |
Lo-Fi Version | Time is now: 14th December 2025 - 01:41 PM |
