hydraulic cams specific for fi or carb set up?, what cam to use when going hydraulic?? |
funk |
Sep 19 2014, 06:54 PM
Member Group: Members Posts: 100 Joined: 23-June 14 From: sandpoint idaho Member No.: 17,531 Region Association: Pacific Northwest |
I went on the web cam internet site and looked and buying their hydraulic cam set up but it says the cam is build specifically for factory fi systems? is their a cam set up that is for hydraulic lifters and carb set up??
Tom |
Sep 27 2014, 02:21 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Lots of negative comments on hydraulic cammed 914's but no one has any thing good to say, so I will.
My 76 had hydraulic lifters and a hydraulic cam ( I didn't have it built, so don't know which cam). My 76 would rev cleanly and smartly to over 5k in every gear. Had plenty of power and others that drove it said it felt just like a normal 2.0 liter. Gas mileage was over 30 and the plugs looked normal. The downside I noticed was the loud valve train noises when left sitting for over a week or two. Quieted down after it warmed up and the lifters pumped up. Would I put in a hydraulic cam if I was building an engine? As one gets older it would certainly be better to not have to adjust valves every 3k miles. One of the reasons I sold my 76, just could no longer do the maintenance myself anymore. If I were using the car for long trips, that would maybe lean me toward the hydraulic cam also. If I were younger and building a pure performance engine, no hydraulics. I would build a 2056 with FI. Tom |
Bleyseng |
Sep 28 2014, 11:07 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Lots of negative comments on hydraulic cammed 914's but no one has any thing good to say, so I will. My 76 had hydraulic lifters and a hydraulic cam ( I didn't have it built, so don't know which cam). My 76 would rev cleanly and smartly to over 5k in every gear. Had plenty of power and others that drove it said it felt just like a normal 2.0 liter. Gas mileage was over 30 and the plugs looked normal. The downside I noticed was the loud valve train noises when left sitting for over a week or two. Quieted down after it warmed up and the lifters pumped up. Would I put in a hydraulic cam if I was building an engine? As one gets older it would certainly be better to not have to adjust valves every 3k miles. One of the reasons I sold my 76, just could no longer do the maintenance myself anymore. If I were using the car for long trips, that would maybe lean me toward the hydraulic cam also. If I were younger and building a pure performance engine, no hydraulics. I would build a 2056 with FI. Tom I don't know if I am younger than you Tom, but at 62 I still do my work. I built a 2056 with a Raby cam and kept the stock FI. With the Porsche swivel feet I hardly ever have to adjust and they are pretty quiet. Yep, hydros do bleed down and pound away until they pump up. They also keep the cam and lifters in constant contact so wear can be a factor. |
Lo-Fi Version | Time is now: 19th May 2024 - 12:15 PM |
