Strut type, What is it |
DavidSweden |
Sep 20 2014, 12:18 PM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I got some 911 struts to do a 5 lug conversion. The struts came with rotors, discs, hubs and M calipers.
When I unskrewed the top of the strut I got a surprise, instead of an insert damper the strut contained a piston and a lot of oil. The only number I found on the strut was L 655.01 Question: Does anyone know what year the strut was manufactured and what type of insert damper do I need to install? Dont suppose its possible to refill and use existing piston? Thanks (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1411237135.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1411237135.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1300.photobucket.com-17452-1411237135.3.jpg) |
Harpo |
Sep 21 2014, 10:13 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
Yes you can although I forget exactly what type Of Oil that I used.
David |
DavidSweden |
Sep 21 2014, 10:48 AM
Yes you can although I forget exactly what type Of Oil that I used. David David, Thanks for the reply. You say you have refilled the damper. Did you fill half way or more and did you replace the O rings? Appreciate if you could give me some pointers so I can avoid mistakes |
Lo-Fi Version | Time is now: 18th May 2024 - 09:47 PM |
