Outer door latch plastic ring broke |
era vulgaris |
Sep 20 2014, 02:37 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
So suddenly yesterday I could no longer open my passenger door from the outside. I took the outside handle off and found that the plastic ring broke, that pushes on the lever to activate the latch.
First of all, it seems idiotic to make a part like this out of plastic! But that aside, can I replace just the plastic part, or do I need to buy an entire outside handle? Attached thumbnail(s) |
Rob-O |
Sep 20 2014, 08:44 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
I just replaced mine. It lasted for two door openings then broke again. Something else must be wrong with mine. Probably the inner door latch needs to be removed, cleaned and re-lubricated. When the inner door latch gets gummed up (that grease is 40 or so years old) the latch doesn't want to move/release. That plastic piece pushes a portion of the inner latch to release the door. So if that inner latch is gummed up, you opening the door handle just squashes the plastic part and can snap it. |
Lo-Fi Version | Time is now: 21st May 2024 - 10:51 AM |
