Has anyone found a way to preserve POR-15, after opening it? |
736conver |
Jan 27 2005, 01:14 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Another tip that works with any kind of paint. Punch a few holes into the recess of the can top. When you pour the paint it drains back in making it easier to get the top off next time. The plastice wrap also wont stick as bad either.
7391420 |
Jan 27 2005, 01:18 PM
Member Group: Members Posts: 353 Joined: 6-August 03 From: boston, ma Member No.: 988 |
I had the same problem, -if you dont get a good seal, the top will harden, but below will stay liquid. If this happens, be carefull when you cut through the top so you dont spray your self with it!!
-good idea on the new empty paint cans, by the 3rd time or so I use one of the quart cans, the top is totalled from using a rubber mallet to re-close it.. -i guess decanting it immediatly into a metal cup and sealing the origional container would be a good idea, so that no residue gets onto the top... |
TonyAKAVW |
Jan 27 2005, 01:22 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I am not sure how well it is going to work, but I bought a regular 1 gallon paint can at my local hardware store and put my 1 qt POR-15 can inside that. Since I pour out of the smaller can, the big can doesn't get anything on the lip.
Not sure how long this will work, as there is a lot more air that the POR-15 sees, but we'll see. Not a bad idea to evacuate the can with duster, or maybe even some welding gas that might be handy. -Tony |
SpecialK |
Jan 27 2005, 01:34 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
I've had pretty good luck using cap plugs (size #18) for the little cans. The sides of the cap plug is tapered and wants to pop back out, but the suction/vacuum caused by pushing the cap into the can keeps it in. POR doesn't stick to the caps so removal is easy, not sure what size the quart can would be, but I'm pretty sure they'd work just as well.
Refrigeration (not freezing) would help I would think, but the guy's at POR told me the shelf-life is only about a year, even for unopened cans (had some new ones cure on me (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) , they replaced them free of charge (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) ) Sorry about the focus of the pic, forgot to press the macro button (IMG:http://www.914world.com/bbs2/html/emoticons/slap.gif) Attached image(s) |
Eric_Shea |
Jan 27 2005, 02:16 PM
A painter friend says thin it with Lacquer Thinner rather than buying their over-price thinner.
type11969 |
Jan 27 2005, 02:51 PM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
do the small cans only have a shelf life of a year? I wonder why my quart can has lasted so long . . .
Brian_Boss |
Jan 27 2005, 02:54 PM
Member Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
IIRC, the moisture is actually a catalyst that triggers the linking of the urethanes. Since a single H2O molecule in the can will _eventually_ make the whole mess solidify, anything you do is just delaying the inevitable. |
Aaron Cox |
Jan 27 2005, 03:22 PM
slightly off topic....
but how do i get it off my hootus? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
mightyohm |
Keep it under dry nitrogen. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Not you Aaron, the POR-15. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:52 AM |
