Replacing oil cooler seals w/engine in |
rjames |
Sep 20 2014, 09:16 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Not dropping the engine to do this due to lack of space and time.
I'm following Clay's instructions which seem spot on. I got as far as far as attempting to take the 10mm nuts off the long studs that hold the cooler to the block. Each of the studs want to unscrew. This is making things much more difficult. I assume that backing the studs out to get to the seals will make replacing the seals even harder.anyone have any tips, or should I bail on this before I do something that forces me to remove the engine? And What's the torque on these things? |
ClayPerrine |
Sep 21 2014, 07:26 AM
Life's been good to me so far..... Group: Admin Posts: 15,474 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you back the studs out, you can remove the whole cooler. Then take the nuts off the studs, put the studs back in the cooler and then screw the studs back into the case. You tighten the studs with a pair of needle nose vice grips. You have to push the cooler forward and work between the cooler and the case, so start with the top one.
This can be done. I did it in a hotel parking lot in Salt Lake city. (IMG:style_emoticons/default/biggrin.gif) |
rjames |
Sep 21 2014, 11:26 AM
If you back the studs out, you can remove the whole cooler. Then take the nuts off the studs, put the studs back in the cooler and then screw the studs back into the case. You tighten the studs with a pair of needle nose vice grips. You have to push the cooler forward and work between the cooler and the case, so start with the top one. This can be done. I did it in a hotel parking lot in Salt Lake city. (IMG:style_emoticons/default/biggrin.gif) Clay, you rock. Thanks for the quick and detailed response and for documenting the procedure so thuroughly in the other thread! |
Lo-Fi Version | Time is now: 20th May 2024 - 03:10 PM |
