Stock injectors on a 2.1L?, Instead of webers |
mtndawg |
Sep 21 2014, 04:39 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I recently acquired a car that was originally a 2L and have been told the engine size has been changed to 2.1, which I have not checked yet? The engine currently has webers. Can I use stock d-jet FI if it is 2.1?
Mark Henry |
Sep 21 2014, 04:41 PM
If it has a carb cam ...then it's no.
worn |
Sep 21 2014, 06:54 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
If it has a carb cam ...then it's no. (IMG:style_emoticons/default/agree.gif) So if you can find out about that detail you have an answer. Yes, I have a 2056 running stock FI, but working around an aftermarket cam has been tricky. Impossible if the cam were designed to take advantage of the Webers. |
Lo-Fi Version | Time is now: 22nd May 2024 - 08:23 PM |
