Stock injectors on a 2.1L?, Instead of webers |
mtndawg |
Sep 21 2014, 04:39 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I recently acquired a car that was originally a 2L and have been told the engine size has been changed to 2.1, which I have not checked yet? The engine currently has webers. Can I use stock d-jet FI if it is 2.1?
barefoot |
Sep 22 2014, 05:48 PM
Senior Member Group: Members Posts: 1,276 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
If you're after a cheap option to try, you can increase the fuel pressure to the injectors by adjusting the pressure regulator. Probably best to install a pressure gage in there to what you're doing. Remember that flow rate is proportional to the square root of pressure to your injectors, thus is you want 10% more flow you need to increase pressure by 1.1 squared, or 21%.
Since you're only increasing displacement by 5%, in theory you'll only need 10.25% pressure increase. Not sure just how much a stock pump is capable of putting out however, no experience there. |
Lo-Fi Version | Time is now: 22nd May 2024 - 10:06 AM |
