Flipping tires over - opinions?, (Hoosier A6) |
mskala |
Sep 24 2014, 02:08 PM
This is my first autocross season using the Hoosier A6. Basically, given my
street-friendly suspension settings, I get more 'roll' on outside edge of the tires and after 8 days I figured I should flip them over if for no other reason than to avoid early cording at the edge. So, I did that and just did the first autocross, and they at first seemed terribly slippery (although the morning was kinda cold) and even by the end of the day still not as good as before. My times were off compared to others. I was told by a 'seasoned' guy I know there that it will take time to get them scrubbed in going the other way. Is this to be expected? Now that I think about it, across the whole tire the wear was not even (it gets a bit wavy), so flipping them must also put less rubber down to the pavement initially. Thanks for opinions. |
Jetsetsurfshop |
Sep 24 2014, 03:51 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Flipped them? Are they all rolling in the same direction as before?
I also noticed that the Hoosiers liked it better when it was warm out!!! I also think, with a flip, we got them to last a year with two drivers. Five to six run each. By the way, with my -camber, we corded the insides. Attached thumbnail(s) |
mskala |
Sep 24 2014, 04:34 PM
Flipped them? Are they all rolling in the same direction as before? I also noticed that the Hoosiers liked it better when it was warm out!!! I also think, with a flip, we got them to last a year with two drivers. Five to six run each. By the way, with my -camber, we corded the insides. You've left out all the best parts Did they feel bad after flipping? How many events did you do in the year? How much camber? (I have slightly over 2) Those look like 205/50/15? I have 205/45/16 My tires get switched around every event, so they are almost always changing direction of rotation. But now that they are reversed on the rims maybe the same parts of the tire are not touching, as the wear is not even across the tread. |
Jetsetsurfshop |
Sep 24 2014, 05:17 PM
Ok...let me look here.
They felt fine after we flipped them. I never changed the rotating direction though. 10 events a year. They were dead around 8 1/2 i'd say. Camber in front was -1 Camber in rear was -1 3/4 205/50/15 A6s, even tired, still are the best way to kick Mazda butt!! (IMG:style_emoticons/default/beerchug.gif) |
mskala |
Sep 24 2014, 06:15 PM
Ok...let me look here. They felt fine after we flipped them. I never changed the rotating direction though. 10 events a year. They were dead around 8 1/2 i'd say. Camber in front was -1 Camber in rear was -1 3/4 205/50/15 A6s, even tired, still are the best way to kick Mazda butt!! (IMG:style_emoticons/default/beerchug.gif) Do you have very stiff springs? There is no way I would be cording the inside even with my more than 2 degrees. I have 180 springs in back and 20 torsion bars in front. I haven't played around with tire pressures, just using 29psi all around. |
Jetsetsurfshop |
Sep 24 2014, 06:53 PM
I looked at the other pictures. The fronts were corded on the outside, the rears on the inside. (IMG:style_emoticons/default/WTF.gif)
Of course, there were moved around the car to get as much as possible out of them. I ran 22psi in the front, 26 in the rear. I won C-stock in my small autocross group with those psi's. I think my springs are 140. I do have a rear sway bar and a big front bar. Not sure if I'm helping or not... Attached thumbnail(s) |
mskala |
Sep 24 2014, 07:12 PM
That's kinda different from mine. This is after 9 days of about 8 runs
per day on our longish course of ~65sec. The more rounded end on the right is what used to be the outside edge until I flipped them. But I have a bulge in the center. |
ThePaintedMan |
Sep 25 2014, 05:57 AM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Mark,
Since you flipped the tires, did you mess with air pressure at all? That last wear pic looks under inflated. The outside edges and sidewall are bearing the brunt but the center is "shiny". Shane, I bet your cording is due to a couple of things. If the rear isn't towed out, I think that the (rear) sway bar might be causing the inside tire to drag slightly. On the fronts, it sounds like you need more camber. Then again, I'm not a big autocross guy so I should keep my big mouth shut. (IMG:style_emoticons/default/smile.gif) |
mskala |
Sep 25 2014, 06:30 AM
Mark, Since you flipped the tires, did you mess with air pressure at all? That last wear pic looks under inflated. The outside edges and sidewall are bearing the brunt but the center is "shiny". I don't have experience if ~29psi is underinflated and causing lack of wear in the middle. I can always try higher. |
Woody |
Sep 25 2014, 07:31 AM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
I always check my temperatures to determine what pressure to run.
Han Solo |
Sep 25 2014, 12:16 PM
Member Group: Members Posts: 288 Joined: 30-September 13 From: Middle Tennessee Member No.: 16,456 Region Association: South East States |
My experience with Hoosier A6 on mid-engine Porsche (Boxster & Cayman) is flipping the tire on the wheel can potentially double it's useful life. Once we figured out what good pressure was for a 2900-3100 lb. car was (36 front, 34 rear) we were able to mitigate shoulder wear. Those cars a very camber-limited (without plates, stock class) and shoulder wear will happen. We would usually do two events, six runs each (plus a few test n tune runs) and then flip the tires. Those tires would then be good for another two events before grip would start to fall off. Using that method, two years ago, I got 70 runs on a set of A6s before cord started to show. Granted, the last 20 or 30 runs were substandard grip but we'd plan on using up the last bit at Nationals test n tune and then slap on the fresh rubber for the competition runs.
mskala |
Sep 25 2014, 04:09 PM
Okay, good info all. I have 80 runs on these, but things still felt good
and the times were good 2 events ago just before the flip. I am going to bump up the pressure from 29 to ~34 and also bring one of those infrared temp guns (I know it's not accurate but just to compare across tread). Hopefully this will use the rubber in the center of the tire and keep the rollover a bit less. |
crash914 |
Sep 26 2014, 02:51 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
man, my 10 year old V710's still look new! I really need to spring for new tires..next year.
I will try some tire softener in the near term, can't hurt. I am trying to wear these tires out..can't do it... |
Lo-Fi Version | Time is now: 5th May 2024 - 02:45 PM |
